Kirjoittaja Aihe: Mitsubishi Galant 1987 E15 2.0Turbo RalliArt  (Luettu 77357 kertaa)
Poissa Tomica93
Vs: Mitsubishi Galant 1987 E15 2.0Turbo RalliArt
« Vastaus #50 : 16.11.15 23:40 »
Here are the pics of the full respray, car was mostly flat AFTER 28 years, little here and there some dent etc.
colour is original ,Sarajevo Weis W18, but in clear coat it was added a bit of a crystal gold pearl, without sun or light you cant see it, it turned out very very good, and I was very satisfied with that.
preparing the car for painting
Preimer:
Ready for paint
Colour:
Painted :D
And some better pics after it got home :)
Some closer view
Galant E10 "RalliArt" 2.0Turbo DOHC
Poissa Skydiver
  • Hallituksen Toimihenkilö
« Vastaus #51 : 17.11.15 10:19 »
 :peukku :peukku
Galant VR-4 -99, Galant 2.5 STW -98, Galant GTI Dynamic-4 -90.
Poissa cubeqtio
  • Valvoja
  • Mr. Cube
« Vastaus #52 : 17.11.15 12:50 »
Nice job!
Mitsubishi Lancer Evolution VI RaceCar - Land Rover Discovery 3 TDV6
Poissa Tomica93
« Vastaus #53 : 05.12.15 12:30 »
Slowly coming back together
a lot of time and effort goes for polishing
But first, PAINT protection , sealant and wax from soft99 fusso
Also cavity wax for doors and under the car
More cinced parts (some of)
polished edge on the tail light
Got a brand new HELLA rear plate lights with chrome look
little before after
And a rear end DONE!
Poissa Skydiver
« Vastaus #54 : 07.12.15 11:52 »
Love the way You pay attention to the details. :peukku So that's why You have to repaint the jack too 8)
Poissa Tomica93
« Vastaus #55 : 15.12.15 12:09 »
Little update, trunk is completed, also an interior and the doors, every little thing was polished, galvanized bolts etc, it takes a lot of time for that (for doors I have spend 2weeks of every day work)
Side skirts are ON :D
Interior COMPLETE
Front light renewd , galvanised bolts etc.
Poissa Tomica93
« Vastaus #56 : 26.12.15 15:53 »
Got some time to finish my custom made mud flaps, base design was for an EVO6
And FRONT end finished, it looks so clean now, better than new :D
here is the pic i like the most :D
And one with all lights ON
Poissa Mikez
  • Eclipse GS
« Vastaus #57 : 26.12.15 18:26 »
Wow, you have really done some unbelievable work on the car! Good job  :palvo
--- Ruoste on ikuista ---
Galant GLSi Dyn4, 2,0 E38 4G63 320tkm
Eclipse GS -94, 2.0 D22A 4G63 304tkm
ex: Lancer GL -96, 1.3 CK1A 4G13 320tkm
Poissa Tomica93
« Vastaus #58 : 26.12.15 21:16 »
Poissa Skydiver
« Vastaus #59 : 28.12.15 10:36 »
 :peukku
Poissa Tomica93
« Vastaus #60 : 06.01.16 14:04 »
Time for new exhaust full 70mm exhaust, with electric cutout on the rear muffler ( for quieter and louder mode), and polished 80mm exit
So here is my design
two pipes through the rear muffler (bigger one(70mm on the electric cutout side, without holes on it), and smaller one (60mm, where gasses are going when cutout is closed(with holes in it, so the muffler can absorb sounds)
remember , the angle of those two pipes is very important, the bigger angle you got, the louder car will be when the cutout is opened
Next thing to do is to port a turbo housing, this needs to be done to prevent boost creep, here it is how it looks before and after around wastegate
Later i had problems with a hot air when boosting. As the car still isnt mapped, and its in brake in proceduree hot air is allready a problem, so it would be big problem during the mapping
So i got almost a brand new intercooler from EVO10
And one video how electric cutout work(sounds)
this is without middle muffler, so basically when electric cutout is opened it simulates straight pipe
https://www.youtube.com/watch?v=30WK_nj8n_c
Poissa MakeM
  • Sir Crankwalk
    • Kuvia
« Vastaus #61 : 06.01.16 23:17 »
I'm also having a boost creep problem with my Evo 3. How much porting did you do to solve the problem?
I heard the stock one is around 22mm diameter, and the flapper is 28mm or so.
Ajakaamme.net - Tarinoita ajamisesta, suomeksi.
Poissa Tomica93
« Vastaus #62 : 07.01.16 11:12 »
hy
the problem is here because you have upgrade your exhaust and probably your intake pipes and cooler.
during the mapping, boost creep is still visible(but not that much) but for completelly elimination I have used electronic boost controller
problem is the position of the wastegate. it is placed 90degrees on the air flow which is bad, so you need to smooth the edges as far as you think you can
the hole on the wastegate is 28mm, flapper is I think 32 or 34mm, cant remember now, mine is from EVO2 but should be the same on yours
so the best solution for this is to go on external wastegate, in that way you will get the best boost controll, but i want everything look stock
Poissa MakeM
  • Sir Crankwalk
    • Kuvia
« Vastaus #63 : 07.01.16 11:27 »
Yep, I thought that 65mm downpipe with race cat wouldn't be too big, but I was wrong ;D
How far was your setup creeping before and after porting?
External wastegate would be ideal for any turbo setup, but I don't really want to modify my car that much at this point.
I love the response, torque and spool that the bigger exhaust gives, so wouldn't want to go smaller either.
Maybe support mods and E85 for fuel to fight knocking? ;D
Poissa Tomica93
« Vastaus #64 : 07.01.16 12:41 »
well i cant answer on that question because i knew what is happening if you dont port your turbo. so i have ported it before mapping
well with external wastegate you wont loose spool or torque, instead you will get better spool (it will spool sooner for lets say 50-100rpm) you wont notice that, but on paper it will be better
because stock wastegate isnt shut 100%, because of the age the surfaces arent flat anymore
+ you will get great boost controll when boost hits
however i recommend you to upgrade to electronic boost controller in that way you almost wont have boost creep, with ecm link offcourse
http://www.ecmtuning.com/product_info.php?products_id=54
Poissa Tomica93
« Vastaus #65 : 10.01.16 17:37 »
Intercooler fits perfectlly
it is 3times bigger than the old one
oil cooler was also relocatted
here how the intercooler looks after redoing the pipes, also a SPAL fan was added for better cooling
Electronic boost controller is installed also
and i got a throttle body from an evo8, much better and faster TPS and ISC sensors
Poissa Tomica93
« Vastaus #66 : 15.01.16 18:47 »
Next, i had to make adapter for ISC to the Eclipse/ early EVO installation
also i had boost leaks on throttle body, and on the outlet of a turbo, so a new flange has been made
Rebuild kit for throtle body
Next i got very lucky and found a brand new middle blend for redesign version complete with instructions and install hardware
also i got a brand new right tail lamp
to me looks much better with it :)
Poissa Skydiver
« Vastaus #67 : 19.01.16 10:25 »
 :peukku :peukku :peukku
Poissa Tomica93
« Vastaus #68 : 24.01.16 21:22 »
another CRASH, fortunately a very light one, Opel didnt pass well haha
All repaired now :)
one with mine second Sapporo with ECS (Electronic controlled suspension)
nice turnup one evening
and meeting with a friend of mine (normal vs RalliArt)
next thing i got is pieces for suspension upgrade
much larger holder bracket for front subframe
and poly bushings for front end
Poissa Tomica93
« Vastaus #69 : 31.01.16 20:54 »
And finally mapping day
Results are 313hp and 395Nm
Finished on 1.3bar boost
Poissa DaJackal
  • EA5A, Z16A, CB4A, D22, E39A
« Vastaus #70 : 17.02.16 15:24 »
I think this could be classified as porn.  :nykii
Miksi ostaa hyvää, kun voi ostaa halpaa?
<RocketD0G> I just sit here with my feet on the table trying to figure out why something doesn't work like suunitteluyksikkö planned
Poissa cubeqtio
  • Valvoja
  • Mr. Cube
« Vastaus #71 : 22.02.16 00:57 »
Like I said on Facebook - liking this one! :)
Poissa MakeM
  • Sir Crankwalk
    • Kuvia
« Vastaus #72 : 03.03.16 10:08 »
Seems to me, that the torque is at quite high RPM and it's a bit down on power.
Of course I'm comparing that to Evos, but can there be as much mechanical difference?
For example, an Evo 3 from the club had highest torque at 3600rpm (430 Nm) on 1 bar boost and after that it slowly tapered down to 300 Nm at redline.
Could the porting affect spool somehow, or is there something else?
Poissa Tomica93
« Vastaus #73 : 03.03.16 10:37 »
Yep, its a huge mechanical difference between 6bolt and 7bolt, for stock engines of course
6bolt angine has 7.8compression ratio
Evo1-2 8.5compression ratio
Evo3 9.0compression ratio
Thats a huge difference, especially for nowdays fuel
Iam running on 1.3bar
Porting is made because of a boost creep, spool cant be much better, with the same turbo
« Viimeksi muokattu: 03.03.16 22:25 kirjoittanut Tomica93 »
Poissa MakeM
  • Sir Crankwalk
    • Kuvia
« Vastaus #74 : 10.03.16 15:45 »
Do you have a boost graph? Or when does it build the desired boost pressure?
Seems to me that you have something wrong with the setup. Don't take this personally, I love your build. Just trying to help :)
