Vs: 2Gen pajeroon 3.2 did kone
Aiemman linkin 3.2 swapin tekijä vastaa kysymykseen
"I would like to put in the 3.2 D.I.D engine with management. Will it fit straight on the (gen 2) gearbox and what do i need to know before i start a project like this?"
näin:
"if the gen2 is a 2.8 then the engine bolts right up if you use the 2.8 engine clutch and flywheel assembly.
I suspect engine mounts are identical.
Your main work will be boost pipes, coolant pipes, A/C, exhaust.
The biggest headache of them all will be electronics to get the engine running.
Get a donor engine from a manual with it's ignition barrel, key and ecu.
The oil, starter wiring and temp sensors can be directly transplanted. It's the engine ecu wiring that scares me but a competent sparky should be able to do it provided you give him the complete ignition wiring system with ecu etc. intact."
http://www.pajeroclub.co.za/forum/viewtopic.php?f=24&t=4879
Eli vaikuttaisi varsin lupaavalta lootan suhteen, mutta uskon myös, että sähköjen takia kokonaisen kolari- tms pelin löytäminen tekniikanluovuttajaksi olisi varsin kannattavaa.
