http://forums.evolutionm.net/showthread.php?t=79642&highlight=evo3
4G63 stroked to 2.3L and baffled Sump..
HKS Steel Crank
Carillo Rods
JE Pistons and rings, Custom Camshafts, Evo 8 Head, Ferrea valves and springs with titanium retainers..
HKS T51R SPL turbo,
Custum Manifold with 80mm throttle body, 6x 1500 CC Injecters, Magnaflow fuel pump with Regulator, HKS 60MM Wastegate.
All ran by an Autronic SMC with anti-Lag and Launch Control.
Car has a stock Evo 3 5 speed, Tilton twin plate clutch, standard Evo3 diffs, and wilwood 4 spot calipers on the brakes..
Its putting out 526kw (705hp) at 6500rpm and 25 pound of boost, and 540nm of torque at 6500rpm.
ja toinen AIKA nopea http://www.drag-evolution.net/
mm videoit tuolla
HKS Steel Crank
Carillo Rods
HKS T51R SPL turbo,
mm videoit tuolla
