Vs: Huoltotoimet EVO 4:een
simonsays sanoi
jos ei mitään tietoa ole, suosittelen vaihtamaan kaikki öljyt, hihnan suodattimet nesteet, tulpat ym.
vaihtovälit ovat aikalailla samat evo 9:n asti ellen ole täysin väärässä.
Jep näin pitäis ol suunnilleen.
Googlasin tämän jonkun vuos sitten:
Service: A
Months: 6
Miles: 4,500 - 7500km
Colour: Blue
1. Check operation of all exterior lights
2. Check condition of wiper blades
3. Check auxiliary drive belts for damage/tension
4. Replenish washer fluid level
5. Replenish intercooler spray system
6. Check brake lines for leaks
7. Check rear differential oil level
8. Replace AYC fluids [diffs + reservoir]
9. Replace engine oil using Millers CFS 10w/60
10. Replace engine oil filter
11. Check brake pads/discs for wear
12. Check tyres for damage/wear
13. Check/reset engine idle speed
Service: B
Months: 12
Miles: 9,000 - 15 000km
Colour: Purple
14. Check all turbo hoses for damage and security
15. Check condition of the air filter
16. Check cooling system for leaks
17. Check brake/clutch fluid levels
18. Check battery levels. Replenish where necessary
19. Check front and rear suspension for damage and security
20. Check steering system for damage and security
21. Check gearbox oil level
22. Check transfer box oil level
23. Check brake/clutch pedals for travel/adjustment
24. Check/adjust hand brake travel
25. Swap tyres front to rear [if required]
26. Check condition of body
Service: A
Months: 18
Miles: 13,500 - 22 500 km
Colour: Blue
Service: C
Months: 24
Miles: 18,000 - 30 000km
Colour: Green
27. Replace brake fluid using Millers Racing Brake Fluid, 300 Plus
28. Replace air filter [standard filter only]
29. Replace coolant
30. Check HT leads
31. Check drive shafts and gaiters
Service: A
Months: 30
Miles: 22,500 - 37 500km
Colour: Blue
Service: B
Months: 36
Miles: 27,000 - 45 000km
Colour: Purple
Service: A
Months: 42
Miles: 31,500 - 52 500km
Colour: Blue
Service: C
Months: 48
Miles: 36,000 - 60 000km
Colour: Green
29. Replace coolant
30. Check HT leads
Service: A
Months: 54
Miles: 41,500 - 67 500km
Colour: Blue
Service: D
Months: 60
Miles: 45,000 - 75 000km
Colour: Red
29. Replace coolant
30. Check HT leads
32. Replace timing belt and balance shaft belt [where applicable]
33. Replace spark plugs using HKS M40Gs
34. Replace fuel filter
35. Check secondary air system hoses for leaks
36. Check crankcase contol system/pipes
37. Check fuel pipes for damage and security
